Victor wrote:I am spending about $33 a year on repair and maintenance.I do have some new issues.
Never buy a car from a poor person who couldn't afford to maintain it.
Well, I think you fail to understand the concept of preventative maintenance, which is repair it before it breaks. More expensive than don't fix it until it's broke, until a major system fails.
You have to understand that part of that $3K per annum is for transmission, suspension parts (I would have to wonder about your tension rod bushings), shocks, brakes, AC, coilpacks, belts and pulley bearings,things that are not replaced annually but the wise budget so the money is there when required?
Ever mechanically exchanged your ATF? Ever installed an auxiliary ATF cooler? If not, you have a new transmission coming soon.
Same for brakes if fluid not flushed every two years, ABS controller is an $1,200 item.
