theronin wrote:Ok update... after i read the codes i put her back together and i started her up. No check engine light. I unplugged the maf and the car did the usual idle to about 2k and then almost sputter and die... did that until i plugged it back in! So that leads me to beleive that it might not be the problem? nissan wants 500 bucks for a new maf lol:eek:
looks like im gonna go see my friend at the junkyard tomorrow!
The ECU clears it's diagnosis codes after you check them.
If it was a MAF error it would have immediately popped back up cause the signal would be incorrect. Drive the car around at run it up all the way to redline at least once when it's all warmed up. If the MAF works fine then it will continue to not give you a code. Also, before you run the car check the connector for buildup or a loose fit. Clean the connectors the best you can.
As for the 02 sensor. It's just something that likes to go out on cars. Pull it out (1" wrench) and shake it gently. If you hear the piece rattling around in there and/or visably see it's broken then you need a new one. However before you run off and go spend $25 make sure it's wiring and connectors are in good condition. If it's black and has alot of excess fuel built up on it then you can take some Gumout Carb Cleaner and spray it down to clean it out.
