Throwing Codes!
Exille
Car: 1993 240sx SE
Well, ijust now checked my ecu, and it threw 11 and 34, which to my understanding is the knock andcam sensors? how would i go about diagnosing this? this is for my 93 Hatch....
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Check them and see if they need to be replaced.
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
Use a voltometer to check voltage befor and after the sensor. If you get a drop your working, if not and voltage is the same i would replace.
sleepyRPS13
Car: to sleep
the easiest way to test the knock sensor is to lightly tap with a "small" hammer close or near to the knock sensor ("not on the sensor"). with the car running, it should retard or a bog almost. then its working
