Throw out bearing
EnjoiNismo
Car: 93 240sx
When changing the clutch, and you have to replace the throw out bearing is this one the correct one they sent me? because the outside layer doesn't spin.. (the old one is on the ground)-thanks
Kraelic
Car: 89 240sx
That looks like the one I used in my auto to manual swap. The outside is the same peice (center hole) that gets pressed onto the carrier for the clutch fork. The 'middle' ring is what should turn as that is the surface that touches the pressure plate to release the clutch.
Kalypso
it will work, they look different but they do the same thing.
the piece that bulges forward on the bearing is watch touches the clutch plate, as long as that spins everything is gravy.
