Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Tue Dec 21, 2004 8:51 pm
Two things:
Yes, your throwout bearing is most likely shot. Since you have to separate the transmission anyway, replace the clutch, pilot bushing and pressure plate too (any kit will have all these). Don't forget to surface the flywheel.
The hard shift into second means that your transmission needs new synchros. Common on the 240. You MIGHT be able to get away with simply changing the gear oil to a high-quality replacement. Some even have friction modifier in them to help older transmissions. Or you could simply have it rebuilt while you have it out and never have to worry about it again. Somewhere near 500 bucks at a reputable shop, parts included.
