pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Fri Aug 11, 2006 2:49 pm
well there is part of your original post that is of concern. you said that it makes a sound when you let OFF of the clutch. a throwout bearing makes a sound when you PUSH the clutch. If your car is making a swishing sound when you have the trans out of gear and you let out on the clutch then it is NOT the throwout bearing it is the bearings on the trans main and counter shafts. If it makes a noise when you push the clutch then it is truely the throwout bearing. the 5 speed trannies in these cars are notorious for the bearings making a growl after you get some miles on them
