bendychicken »
https://forums.nicoclub.com/bendychicken-u8295.html
Fri Aug 22, 2003 2:26 pm
It's what presses against the pressere plate's diaphram like springs to release the chutch's grip. This is why they are also known as release bearings. when you press the clutch pedel in, it moves the clutch fork forward torwards the pressure plate. But the pressure plate is spinning with the flywheel(it's bolted to it) and the clutch fork is not(it's clipped on the the stationary bell housing). so if the clutch fork were to directly press on the pressure plate there would be lots of grinding and snapping and brakeing of various mechanical objects. so what we need here is a bearing to apply liniar force to the pressure plate, but to also spin with it. this is the perpose for the throw out(release)bearing. Hope that helps.
OK, so has anyone got any ideas on where to find some pics? pleeeeaaasse. Cmon, you know you wanna help me out.:icesangel
