duffman1278 »
https://forums.nicoclub.com/duffman1278-u61344.html
Fri Sep 14, 2007 11:05 am
I had that exact concern also but when I looked at it, you have to realize that for one, the hole in which the guide goes into is small in depth so whenI installed mine it was like your situation, just make sure to hold it as you put the clutch plate over it, I had one of my friends hold it while I went to get the clutch plate than when I was installing it I just carefully put it in without touching the guideand I torqued it down. when you tighten it all down it should be in there pretty solid. As for the TO, there's 2 sides one side has a fillet and the other is flat, press the fillet side into the shaft so when you install it the fillet side should face the inside of the transmission, not towards the engine side.
