l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Mon Apr 16, 2007 2:22 am
Evan,
Aye, it was me. Everything seemed to go in fine. Like I stated above, the bearing itself is different (Z31 vs Z32) but I assumed that since the Z32 bearing is what came with the clutch, I should probably use it :wink . I will not be able to tell you what I think of it for at least a month, till I can get the car on the road. What I can tell you about it is that everything went in smoothly and matched perfectly. The _one_ gripe that I have is that it did not come with any instructions... I know how to install a clutch, but I thought that it should have came with _some_ documentation / warranty info, but I found none.
I measured the clutch and pressure plate before I installed them because I had heard that RPS has had issues recently with shipping incorrect items, but it all looked fine. The clutch disc itself was identical to my OEM that I had removed, but I will assume that this will have a much higher clamping load than the OEM. Anyways, you can view my galary on Photobucket for more pics or email me and I will give you more info / link to my build journal. Thanks!
