throw out arm pivot broke... anybody seen this happen?
Rival SE-R
Car: 91 se-r, 90 240sx fastback
driving around last night the clutch pedal jammed up... i pulled over and looked under the car and saw the throwout arm was twisted wierd, i figured the spring clips that hold it in place where original (90 240 w/154k on the clock) and worn, i figured they just fell off and i would have to replace them and the slave cylinder since it pushed the piston out to far and was now leaking badly...
upon closer inspection this afternoon however i noticed the ball pivot the throw out arm sits on inside the bell housing had broken in half... i have never heard of this, and was wondering if anyone else has?
if this is more common then i thought, does anyone know of a stronger alternative?-pete
llamabeta
Dont see it alot but has been known to happen. It is considered a rather weak part on the transmission. It's recommended to upgrade it when increasing power and changing to a more heavy duty clutch.
http://www.splparts.com/Parts/...t.asp
$25 will fetch you a beefed up one.
Good luck.
