throttle response
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
nistangclan727
Car: 03 maxima
i have trouble with my throttle sometimes and was wonderin what i can do to better it
NismoB13
Car: 1994 Nissan Sentra SE-R
I'm assuming this is in a 96 G20. Check for slack in the throttle cable. Basically do a good tune-up including spark plugs, wires, cap, rotor, fuel filter, etc. It will improve throttle response.
Zerogravity
Car: 1992 Sentra SE-R
when you change the intake and get rid of the snorkle, essentially you ar now sucking in warm air. If you are creative enough, make your own cold air intake and get the air sucking from your bumper. You will gain back your throttle response.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
