XterraVersa wrote:I seriously think it is in your shifting footwork, not a design flaw.
I tried on my Xterra to get the trottle to hang. If I press the clutch before I was off the throttle the RPMs would go up or stay the same for a second or two. If I am completely off the throttle before the clutch is fully disengaged, the RPMs drop.
You won't be able to replicate the Versa's throttle hang in your Xterra because the Versa has electronic throttle-by-wire. That's what causes the common throttle hang in all newer manual nissans.
I'm not a big fan of throttle-by-wire personally. I can see the potential benefits but at this point in early implementation, they don't outweight the downsides.
I'd imagine there is a way to reprogram the behavior of the TBW, but you'd need access to nissan Consult equipment and knowledge of how it's programming works.
