throttle position switch wiring not in the fsm?
clss240
Car: 1990 240sx hatch
i cant seem to find th wiring diagram for the throttle position SWITCH. not sensor. in the fsm for my 93 dohc. the wires pulled out of the connector. i noticed it is the engine bay connector harness f24. would anyone mind peeling back that small rubber boot on theres and tell me which order the wires go. its the black connector that goes right into your tps on the throttle body. should be green with black wire. green with blue wire and yellow wire. THANKS in advance
vancouverbc
Car: 1991 240sx
thats the throttle valve witch for achttp://img522.imageshack.us/my...5.jpg
bottom right corner
clss240
ur the man thanks i feel silly
