Throttle Position Sensors difference?
ska69
Car: 200sx s13 ca18det
Hi,
What's the difference between the auto & manual throttle position sensors?
I understand I can swap a ka24de sensor to a ca18det throttle body, but what's up with the auto & manual difference? (the manual one costs more )
I have a ca18det auto engine (the car had an auto transmission, but was later swapped to manual)...does this mean my sensor won't work? if it will, then can I get a new ka24de auto tps sensor?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
if your engine is an auto, get an auto speed sensor. I think there is an extra plug on the manual sensors, but can't remember exactly.
ska69
you mean the manual TPS won't fit my auto harness?
maybe the TPS is somehow connected to the ECU (through the main harness) and if the ECU was swapped, then the TPS should be as well?
sjbsuperman1425
CA18DET
yea i think you got it right. i was a little tired earlier haha
the TPS you get should depend upon the ECU you are using.
Manual ECU -> Manual TPS and vice versa
ska69
then how is my Manul ECU working with the stock Auto TPS?
float_6969
The auto tps has a switch in it that isn't used by the manual ECU. IDK why one is cheaper than the other.
ska69
So I can simply get the auto TPS switch and I'll be fine?
DoriJai
so a ka24de tps will fit the ca18det?
