mr_wizard wrote:Idea's?
Just shell out the 10 dollars for a voltimeter man. Once you get that, you can at least eliminate the tps problem and know for sure. once the tps is working rite and you still can't rev past 5k in neutral - it's most likely ur maf sensor or the maf connector, mine did that, replaced the maf & helped w/ that issue.180fan wrote:you need a volt meter
Then once that is good, change over to K Ohms & see if it is correct...AZhitman wrote:Adjustment:
If Throttle Sensor is replaced or removed, it is necessary to install in proper position, by following the procedures shown below:
1. Install Throttle Sensor body in the Throttle Chamber. Do not tighten bolts. Leave bolts loose.2. Connect Throttle Sensor harness connector.3. Start engine and warm up sufficiently.4. Measure output voltage of Throttle Sensor using voltmeter.5. Adjust by rotating Throttle Sensor body so that the output voltage is 0.45 - 0.55 volts.6. Tighten mounting bolts.7. Disconnect Throttle Sensor harness for a few seconds and then reconnect it.
I'm trying to help you man, I really am, but you're gonna have to figure it out on your own if those instructions weren't clear enough. I don't see how it can be more clear.AZhitman wrote:Trouble Diagnoses:1. Disconnect Throttle Sensor harness connector.2. Make sure that resistance between terminal #1 and #2 changes when opening the Throttle Valve manually.Looking at the "pins" of the connector w/ the locking tab of the connector pointing up, terminals #1 is the one on the LEFT. #2 is in the MIDDLE and #3 is on the RIGHT.
The results of the test should be:
Accelerator Pedal Condition Resistance in k OhmsCompletely released Approx. 2Partially released 2 -10Completely depressed Approx. 10If test shows "No Good", replace Throttle Sensor.
There's holes in the instructions where he sort of expects you to know alot of this stuff. I have no clue on how to use a multimeter. So this "4. Measure output voltage of Throttle Sensor using voltmeter." does not make any sense. Where do I put the positive and negative pins? It does not say. After I warm up the car, do I leave it on? It doesn't say that either. Because if you were to leave it off, where would you get output voltage from? And if you had the car on, you have to disconnect the plug to measure anything. So where would you get the voltage then?brokeAs240sx wrote:Just follow the instructions... try the K instead of the M.
But first, you have to adjust it w/ the correct voltage (V):
Like you said, if the TPS is busted, you won't be able to get those values (test shows "no good"), but at least you'll know how to do it when you have the replacement...
Like 180fan said ^^^^^180fan wrote:you need a volt meter to do the tps testing. and yes you turn the tps to get the readings with the engine off but the electronics on.
I missed the part about it only being in the "ON" position. Doh.brokeAs240sx wrote:Ok, first things first.
We are only going to use the voltimeter (volt) part. If I don't explain how to use a voltimeter well enough, please search through google - as that's how I learned, so I know you can do the same.
When adjusting the voltage, the car should not be running - but put in the ON position.
I use the FSM religously, but I must have a different version because the only information I have about a TPS is a description of what it does. I looked through this thing SEVERAL times, I know I do not have anything on that.brokeAs240sx wrote:OkNow that it is on, you can do your testing.
To know which wire is positive and negative, please go here: http://www.zeroyon.com/ and d/l the fsm for your car... In there, you will see any and all wiring diagrams. It's the FSM, use it, love it, it's your friend.
I would tell you which wires are positive and negative, but I don't remember off the top of my head, and I think you would learn a lot more once you figure out how to do this on your own - the FSM actually outlines how to test your TPS also...
I asked around about this in detail, I think the part I'm missing here is you have to actually peel back the insulation on the TPS wiring in order to get a reading. My battery is fine, I've measured that, but I'm not going to risk f'ing up my TPS wiring trying to measure voltage like this.brokeAs240sx wrote:The voltage should read .4 when closed... Your battery, if you just put the negative prong on the chassis or neg terminal and positive prong on the positive terminal, should be about 12 - that is the scale you want... The voltimeter gives you different scales for different applications... you want the lowest volt reading usually listed as 0-20 or something.
Once you do all that, the instructions should be clear.
I recently just frankensteined an OBD II motor into my S13 with several mods and little help from anyone on here when I blew my motor. It was just me and my FSM. Spoon fed? I think not. I'm just not afraid to ask questions when I don't know what the **** I'm doing.brokeAs240sx wrote:I understand you are getting frustrated... but if you can't figure some of the simpler things on your own, how do you expect to fix your own car in the future when something more serious happens? People can't spoon feed you all the information all the time...
I hope you d/l the FSM and look through it, it should help you a lot.
And do you have the real FSM (there's 2 versions floating on the internet, the real scanned version and the version that someone typed up similar to chiltons)??? Cuz if you look through it religiously like you say, there is a specific section detailing how to adjust and check the TPS... I know, I just used that section last month...180fan wrote:If you're going to switch out the tps anyway, it will still need calibration with a volt meter regardless.
