Throttle Position Sensor
General discussion area for the U13-chassis Altima
Rftomlin
Car: 94 Nissan Altima
Does anyone know how to check the throttle position sensor on a 94 nissan Altima automatic 2.4 . I have 12 volts on the signal wire but I do not have the 5 volt reference voltage from the ECM as stated should be at the harness connector.. I dont know does the connector have to be hooked up to a good working TPS and then the 5 volt reference will be released from the ECM? I dont know. Does the 5 volt reference suppose to be there at the connector as soon as the key is turned on, but not started? Please advise thanks Randall
Return to “1st Generation Altima Sedan (1993-1997)”
