sideways24d »
https://forums.nicoclub.com/sideways24d-u64505.html
Sat May 12, 2007 2:20 pm
Make sure you wash the throttle body with soap and water real well on the edges and the back of the throttle plate. To start i used brake cleaner, wiped it down, then used soap and water. I only sprayed the cleaner once though. With the intake off I would clean the MAF if you havent yet with denatured alchohol.
