Throttle Position Sensor help.
Downshift_Sideways
Car: 1992 Nissan 240sx Coupe
I was reading my codes on my ECU. and I threw the TPS sensor.
I have an sr20det.I noticed whenever I would push down the gas pedal there would be a second delay and then the rev's would raise.
So I went ahead and assumed it was the TPS sensor.Now I read the FSM on how to adjust it.
iirc. the TPS sensor should be at a .5volts when the throttle is closed.
I pulled out my multimeter and took some readings, along with some pictures.
These are the reading with the car turned on. from the female connector.Far left pin:Middle pin:Far right pin:
Those should be accurate readings from the wiring harness to the TP sensor itself.Continuity still exists on the ground wire, even when the car is shut off. so thats a good sign.
No matter how much I try adjusting the tps sensor, the most volts I can get is .20Does this mean the TPS sensor is bad?
I just need a few second opinions before buying a new one. Does anyone know the Correct place to put the multimeter probes to get the .5v reading??
Hijacker
Car: '92 240sx Convertible
'94 F-150
You test the plug on the tps...
