Q45tech wrote:The engine ecu needs at least 3.8 volts from TPS to know you want WOT acceleration program.
As currently adjusted, it only goes up to 2.0 Volts at WOT. I haven't had the throttle wide open on the road, but it seems to run fine up to normal cruising speeds (75 mph).
Q45tech wrote:Misadjusting the engine to solve a transmission fault is not wise.
I agree....I sure would feel better if it shifted properly when the TPS is set per the manual......but if this is a transmission problem, what component could it be?
Q45tech wrote:The tps tells transmission what load you want 8 different steps and the transmission tries to adjust shift pressure to match load........TRIES is the key word here.
Funny thing is, at current TPS setting it shifts pretty much as expected and doesn't seem to have any serious problems. Is there any way to tell from these settings and symptoms what the problem component might be?
