bmconway76110 »
https://forums.nicoclub.com/bmconway76110-u268037.html
Sun Oct 23, 2016 12:28 pm
It will float repetitively and rhythmically about 300-400 RPMS
If you think it's a trans issue, don't. That what I thought at first. It's probably just the truck bucking due to the fluculation in the RPMS
It happens in gear or park. It is most certainly an issue with air fuel delivery and or management.
Now, with all of that said, I did throw a P1130 swirl control valve code this morning.
I need to check the vacuum lines to make sure my friend and I didn't forget something when we were cleaning the MAF and the throttle body. I cleared the code to see if it returns.
I don't know anything about the swirl control valve, so I am relying on you guys. Could that cause my symptom?
