throttle issue.. relating to vac
MAKAKO
Car: AE86(F-Prod SCCA Track) Drift, EG8 civic, 91 EF, Honda 599. (update2019) 01 silverado turbo ls1, buell xb12 E85 tune, and a bunch of destroyed hopes and dreams
wondering what is going on with my 91 kade. i've built her up and have a perfect harness and sensors. i start her and she idles like a benz. when i hit the gass she wants to bog . but the ecu keeps her idling. i notic if i keep teh vac under 15lbs she'll rev up til 4500. anythign under that value she bogs. and if i just hit the pedal she og then raises then bogs. i'm thinking i have misses somethign on the tps or i have missed somethign regarding a vac line on the bottom of teh throttle body
NISTECH
to me it sounds like an airlow issue, Either the meter is bad or you have a break in the inlet tube between the MAF and the throttle body.
s13sr20chris
ditto
