Seanzyyy »
https://forums.nicoclub.com/seanzyyy-u135160.html
Tue Jan 12, 2010 3:52 pm
yea,
well the problem is back.the starting issue isnt as bad.sometimes it has trouble turning over.
but the loss of power when given too much gas while in neutral/clutch engaged is still evident.
im going to change my air filter since it was dirty and maybe it'll be good help or just temporary like the MAF cleaner.
after that it may be the o2 sensor so ima change that.
a buddy of mine said that the way i described it, it sounds like it could be a bad vacuum leak?
idk, im gonna check my codes hopefully tomorrow to see what the deal is.
also, i think im running rich.
when i try to give it gas and it starts to lose power, smoke comes out from under the car and it smells like fuel.
i tried researching a bit and came across a topic in a mustang forum where a guy said to use 87 otherwise the OP would run rich?
i run 91 octane.should i go to 87?(just figured 91 was the best, ya know?)
