Throttle cable with sr braket
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
What year of 240 has the longest throttle cable??I would like to use the throttle cable bracket that came with my s13 engine..Iv been using a custom made thing,and i just what to use the stock piece..I have the stock throttle cable in it now (92 240sx DOHC KA) and its to short..Will i have better luck with a SOHC cable or a s14 cable..??I have a JDM cable to,but im sure that one's to short to..
wildacexxx
Car: 2002 Q45 nav sport
im using a 91 throttle cable and its just rite. dunno why urs is shorter
sr20detmaybe
Car: 95 240sx
my s14 cable works fine with my s14 sr, idk if itll work as good on the s13 bc of the difference in throttle body location
9240sx
And your using the stock sr20 bracket??And the cable fits??
iknowyoulike
That's weird i have a 92 dohc cable and it's too long....
9240sx
Would it make a differents if im using a JDM gas pedal..?
Rosco
Car: 91' SR'ed Hatch
My 90' SOHC cable just makes it....
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
yay found my answer
somehow my sr bracket broke completely in half a few weeks ago
ca18det_boy
there is a stopper behind the gas pedal....bend it down just a hair and you'll have the length you need.
9240sx
Ok,So all years of 240's work then??I think im going to find a SOHC cable.And see if it works.Since i know the one on my car now wont fit..S14 cables sould be a the same size as the DOHC s13 right?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
same motor so i would think they are the same
only one way to tell
9240sx
I checked and Nissan has a different part # for SOHC,DOHC s13/DOHC s14 throttle cable's so they are different..Just not sure how..I checked and the s13 dohc and the s14 dohc cables are the same lenth,But look alittle different..Just small things..Im going to buy a sohc cable next week to see if its longer or shorter then the dohc..
drifter_for_life06
Car: Daily: '16 WRX
Exocet
if you got a friend in the metal industry they can probbaly make you a cable
oneslow240se
Car: 91 240se
my 91 throttle cable is long but short at the throttle bracket, i just modified my KA throttle bracket and so far it seems to be holding pretty good..
