Dremel tool... strip the black covering back exactly how far you need it... slide nut section to the end to get it out of the way, dremel off the spiral metal pieces but DO NOT cut the actualy cable, then slide the nut section securly back, tighten on the ca throttle cable bracket, and give it hell
