throttle cable
240DRFT
hey i already searched and got mixed opinions, but i need to know whether or not the kae throttle cable will work with a kade. somepeople say no, some say yes but its a tight fit, but i need to know for sure.
koukiKA240
Car: 1991 240sx KA-T
replacing a throttle cable is easy and usually can be ordered quickly or found in a junkyard. Just wait untill you have the motor in place on its mounts and then run ur stock KAe cable to the DE TB and see if it works, if it doesnt then start calling junkyards. thats the best i can do.~Sam
Tx-Sx-FS
Car: S13 KA-T
bump, more input cuz im having similar problem... kade in kae car, seems to be alot of slack left over, do i just need to tighten some how or get another cable...searched so no baggin plz.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
240DRFT wrote:hey i already searched and got mixed opinions, but i need to know whether or not the kae throttle cable will work with a kade. somepeople say no, some say yes but its a tight fit, but i need to know for sure.
The throttle cable needs to be changed. The SOHC cable is shorter and doesn't have enough travel. I have heard that people have stretched it across the engine. Maybe it can be done, but it will probably look like crap.
Tx-Sx-FS
Car: S13 KA-T
mine is sohc to dohc swap, so i have the sohc cable and its too long...or am i just not tightenin it up enough?? its layin across the valve cover and still not tight so what am i to do??
