Throttle Cable on Greddy Intake Manifold? RB25DET
Tripz
Car: S13 RB25DET
I've tried searching, but haven't had any luck coming up with any direct answer. I have a Greddy intake manifold installed and the cable that was used was too short. Is there a replacement that is longer than the one I have? I'll attached a pic below, and I want to run the new throttle cable near around the valve cover and near the injectors, so it's hidden. Sorry if this has come up before, but I just want had no luck (probably wasnt searching hard enough), and I want a direct answer if possible. Thanks
eh?
I believe the S14 cable works.
Bluefire
Looks like the single cam 89-90 240sx cable... you need the dual cam ka cable from the 91-94 240sx
-Bluefire
300Plus
Car: 1995 S14 w/ Rb25det Series II
Why have the throttle body linkage on that side anyways? why not use the bracket flange on the other side of the greddy and flip the TB
