Postby
elecfus »
https://forums.nicoclub.com/elecfus-u268885.htmlThu Nov 17, 2016 4:36 pm
you could have just used some rubber hose, cut a small sheet out of it, cut a strip so it will slip around the cable and fitted it. sticky tape will eventually leak gunk into the cable and jam it as the adhesive flows with heat.
Postby
everpresentnoob »
https://forums.nicoclub.com/everpresentnoob-u268012.htmlSat Nov 19, 2016 11:31 am
Im more partial to going to the hardware store and getting nylon spacers from the hardware aisle. they just slip over the cable and then a ziptie or two hold the in place. They wont leave goo like your tape will, or compress like some rubber hoses will.
Postby
areus »
https://forums.nicoclub.com/areus-u266225.htmlMon Aug 14, 2017 3:23 pm
To clarify, I put the cardboard on the black plastic piece that holds the pedal in place. Not the cable itself. This made the pedal's default position snug with the broken bushing.
