Bigvinnie »
https://forums.nicoclub.com/bigvinnie-u27626.html
Sun Dec 18, 2005 7:54 am
The KA breaths fine, but the KA already has a signicantly rich ecu tune. Every time your butterfly opens in the lower RPM the KA is dumping more fuel than needed, probably to help with lowering the NOX with richness of the fuel. (Fuel as a liquid is harder to burn than air, actually lowering emissions, obviously bad for performance)So now lets say you install a larger TB, and the TPS is positioned the same that the smaller TB was. You just increase throttle correction and have allowed more air to enter the engine, than having the smaller TB. More air is now used with the fuel leaning out the engine more. This will overall increase acceleration, torque and HP.
EDIT:Just did a bit of investigating on TB diameters, and it seems that Honda knows what there doing.Acura RSX Type-s K20a/TSX K24a use a 62mm TB for a 2.0~2.4litre displacement engine.Integra R type B18 uses a 62mm TB.The upgrade for prelude H22 is 62~65mm.
^^^^^All of these engines show greater improvement than the KA with lower displacement.^^^^^^^^
L28 MPI guy's are also utilizing the KA TB, and have noted that a larger TB than the KA TB could be used.........
The stock diameter size of the TB for the KA is fine if your into passing smog, for swirl and atomization, as far as increasing performance don't think highly of it.SR20 also uses a 60mm TB and is 2.0 litres.......
If you ask me something just isn't adding up.....
Modified by Bigvinnie at 12:45 PM 12/18/2005
