slickroger »
https://forums.nicoclub.com/slickroger-u85557.html
Mon Jun 01, 2009 10:20 am
very easy just get some throttle body cleaner.
remove the pipe that goes from your intake manifold to your airboxstart up your whip there should be a little lever that will simulate the gas pedal. if you have cruise control there will be 2 levers.Now right where you removed the pipe just spray the cleaner when you open the whole up with the pedal or lever if you havent done this beofre it'll probably be black in there.
I can help you out if you want Qxxx4
