throttle body
dcmxsa
Car: 1990 nissan 240sx
Can you use the nipple right below the throttle body for the Wastegate actuator..on a Sr20? Ive seen people that did it..but some say you cant? Most of the time its just capped off.
Thanks
VigVoodoo
As far as I know its for the Activated Carbon Canister (Charcoal Canister) and will not work as a wastegate signal.
dcmxsa
0oh..mines been plugged up since i did the swap..right now i have my bov T'ed to my wastegate and boost gauge..but i dont wunna weld a nipple onto the hotpipe if i dont have to. ive seen pics of people that did it so..i jst need to find out if u can or cant.
Thanks.
VigVoodoo
Try hooking up your boost gauge to that outlet and if it reads the boost just fine then go ahead and use it for the wastegate.
dcmxsa
yea sounds good? Any one else have any input?
C - ROD
Car: SR20DET pignose hatch
i run my actuator from that vacuum port on my redto & it still opens the wastegate when it is susposed to
180fan
Car: 89 fastback
you can't use the one for the carbon canister.
dcmxsa
ok soo C-rod you are running off the port right Below the Throttle body, and then there is the Tw0 ports about it for the BOV and FPR right. is the port right below the TB a boost only port or is it VAC/Boost?
Thanks
dcmxsa
karmakaze
Car: 98 240sx SE
the port coming off of your throttle body is for your charcol canister. if you have removed your canister, then block off this port. the other 2 are coming off of your plenum. run your blow off valve to one of them. your bov should be the only item on this run. your FPR/boost gauge goes to the smaller port on the side of the plenum. anything else, like a boost controller or whatever, goes to the 2nd larger port on your plenum. if you have nothing else, block this port off.
dcmxsa
Ok..so it wont work for your wastegate? right now i have my BOV T'ed to my wastegate, some people say this is better so say u shouldnt do that. so im still a little confused.
VigVoodoo
dcmxsa
Hey i no about that..but i dont have a sidemount IC so i dont have a cold pipe nipple for the wastegate.
VigVoodoo
Well then go to the store and buy this and just screw it into your coldpipe.
VigVoodoo
Lol. By the way, JB WELD is you FRIEND!!!
dcmxsa
thanks..i used a brass nipple fitting..and tapped it and screwed it in..i havent used JB weld on it yet..but i prolly will.
