Laker4ever »
https://forums.nicoclub.com/laker4ever-u185884.html
Thu Sep 29, 2011 8:10 am
I have a 2003 Nissan Pathfinder SE. VQ3.5 AT with about 76,000 miles.
Never had any issues since day 1, only oil and filter changes.
Last couple of weeks i had days where after starting the vehicle, pressing the Gas pedal would do nothing. Turning off the engine and turning it back on, would fix it, and it would drive great. Then came a (CEL) check engine light and i read a P1121 code (throttle body actuator). So i cleared it couple times, and it came back after a week or so. Two days ago, i started the engine and it would die right after starting. Pressing the gas pedal when starting didn't change a thing.
So I was able to buy a new HITACHI replacement part and installed it with a new gasket. I torqued it according to specs of about 70 inch/lbs. The first time i started the engine, it stalled. Then i attempted to follow the reset sequence that i found on the web. (one was for 350Z, the other for Altima), they were the same. The last step of the reset (volume air adjustment) shows that the CEL should blink after the 20 second of gas pedal press and then you need to release the pedal within 3 sec of the light getting solid again. My CEL never blinked, it was always solid under IGN ON, ENG OFF. I cleared the old code P1121.
But still, after doing that, the engine starts well and only problem is high idle speed. I remember that in P or N and AC off, it was doing about 750 RPM, with AC slightly higher. Now with the new TB, in P and N it revs at about 950-975 RPM. At one point i got another CEL code of P0507 (High Idle speed) which make sense.
I've found that this issue is common on such TB replacement jobs, but i couldn't find a solution.
Is there a different reset scheme for the 2003 Pathfinder? Was that OK that i never got the CEL to blink towards the end of the reset sequence?
Is that true that the ECM will eventually tweak the idle speed down by itself?
Or do i have to go to the dealer for them to connect it to the computer (Consult II) to have it programmed correctly?
Thanks much for the feedback.
