Throttle body question
NCS13240SX
Car: S13 PROJECT CAR
Hey what goin on
I got the emissions removed cleanly and gettin ready for the first fire
im in the middle of hookin up the cold air intake on it
two questions
the throttle body has a little brass fitting for a line on it but do not know where its supposed to hook to
also by the filter there is a fitting for a line but i dont have anything that it hooks to, so my question is what are these to?
this is the brass fitting im refering to is right next to the tag on it, anyone know what line that is or the line by the filter on the ebay intake is?
biggie
Coolant normally flows through the throttle body, but most people just remove it and loop it and just leave those open.
The fitting near the filter is emissions related if you have removed that you need to cap it.
NCS13240SX
I got the two coolant lines ran through the throttle body
so the little brass fittin stickin up the top of the pic is an emission line?
biggie
I'm confused now. The only fittings on the throttle body are the coolant lines.
NCS13240SX
Look at the pic and right next to the tag, if you look there is a lil brass fitting, the size of a vacuum line would be.
you have the two coolant fittings on the side then right below the tb is the lil brass guy stickin towards the front of the engine bay
if i had paint i could point towards it, but work comp and they wouldnt like me doin that lol
biggie
I can't find a better pic to look at it, but I would assume that it is emissions related and needs to be capped to be safe.
NCS13240SX
Ok thanks for the help man
you know anything about the fittin on the intake near the filter that looks like a vacuum line but not sure what its supposed to be hooked to
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
There should be three nipples by the tag, coolant in and out....i cut that part of the throttle body off and bypassed the coolant through there. The small nipple is supposed to go to your evap canister ... I pulled it and welded the whole closed. All you need is cable pulley and tps sensor.
NCS13240SX
AWESOME, thats what i needed to know
thanks a ton
now i can stop stressin bout that.
still cant figure out the cold air intake part though....
biggie
If you removed emissions the only connector on the intake pipe to be connected is the IACV which is close to the TB, the rest would need to be plugged.
NCS13240SX
thats the one i have connected and the one to the oil breather, but i will have to take a pic and show you what connector im talkin about on it then
