throttle body question
lotusCA18DET
Hi, because the set-up of my ca is a bit different then standard (it is a ca mounted in the middle of a 1969 lotus europa) I like to run the throttle body without the coolant pipe's (throttle body is at the back of the engine) will I get problems doing this or am I okay?thanks,rick
btm88
Car: 1993 S13 Convertible
You'll be fine. Many people run their Ca w/o the coolant lines going through the throttle body, in fact I am running it that way now.
float_6969
Coolant lines on TB are NOT needed. I think everyone eliminates them. I think it was old left over thinking that the throttle plate would frost up and stick like used to happen in carby setups.
