king_johnthegreat »
https://forums.nicoclub.com/king-johnthegreat-u2837.html
Fri Jun 13, 2003 7:14 pm
The truck's block lacks a great deal of the meat found on the 240 KA block. The 240 also has added brackets that extend to below the oil pan flange surface to bolt to the transmission bell housing and the block sides. Much more sturdy, and an absolute must for high hp and torque. The 240 also runs the oil pump directly off the crank, inside the lower timing chain cover; whereas the truck runs the pump outside the lower timing chain cover, on the passenger side. The distributor on the truck has an internal coil, and is run off the crank. The 240's distributor has an external coil, and is run off of the idler sprocket inside the upper timing chail cover. Beyond that, much about the two is the same: head castings, oil filter blocks (Very similiar), cams interchange, as well as the rest of the valvetrain. The bottom end on the 240 is bullet proof, but the truck sucks. The 240 has a one piece crank girdle, but the truck has individual two bolt main caps. Here are some pics of my swap (I am getting more, but I ran out of film).
Thanks for confirming my wiring ideas for the TPS, BTW. More to come...John
