Throttle Body plate adjustment??
meet07
Car: 89 180sx rb25det
I know the tps sensor is suppose to be adjusted to 0.4-0.5 volts but what about the plate?? I have a q45 TB on a isis style manifold....
Im not sure if the plate is suppose to be all the way closed(engine breathing through the IACV) or if its suppose to be cracked a little?? And if its suppose to be cracked a little...what is a little?
Thanks
Joe
as far as i know, plate closed. IACV should control idle.
meet07
Thanks a bunch Joe..I asked this question in the past and didnt get a answer...
Thanks
Bluefire
I remember reading in the sr manual that there is a specific adjustment for the throttleplate. Either way you shouldn't have to touch it from the factory. If your having idling issues its because of something else not the TB
Joe
well even if im wrong, worst case scenario is the car wont idle. so just give it a small crack if its struggling BUT it shouldnt NEED to be open to idle.
the IACV should take 100% control of the idle.
meet07
Bluefire: I read that in the past but I have already made the adjustment...Im sure I got it close but wanted to know for myself....
