THROTTLE BODY ON 80 720
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Car: 1980 720 5-speed
I looked over my truck today and I see that I have throttle body not carb is this factory?
PEZi
no... everything through '85 had a carb in it
Well then it looks as if it has spacer as well I will try and get a picture of it up for you guys
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
89720 wrote:I looked over my truck today and I see that I have throttle body not carb is this factory?
It was an option for the 1985 ST pick up.
PEZi
well he has an L series in it... so if it has a throttle body this sounds like a custom deal
seang
Car: Ford Fiesta ST
I thought the 1980 model came with either an L20B or a Z20 4 plug.
I have the l20b
flinterman2000
PEZi720 wrote:well he has an L series in it... so if it has a throttle body this sounds like a custom deal
According to wakopedia, the L20B switched to fuel injection in 1977 outside of the US. So it tends to relate that the engine is from a 200 sx import and swapped into his truck.
PEZi
interesting.... that's kinda cool if someone put it in there
flinterman2000
Yeah. Probably thought it was an upgrade as it was fuel injected.
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
pics please!!!i want to do a swap on my truck and just cant decide what......i want sumthing different...im thinkin a low boost l20b..hmmm idk i dont want a ka though...if i can get sumthin else with a throttle body that would be sweet!!
flinterman2000
bracktheron720 wrote:.if i can get sumthin else with a throttle body that would be sweet!!
Anything with a throttle body is tough to convert to the truck. There's high pressure (35 psi and above) fuel pump to install, the wiring the contend with as well as mounting brackets to fab, instruments to change to suit your choise, among a lot of small things. All this = headache. I know because its been 4 months and mine is not yet complete.
By the way anyone can supply a wiring diagram for a Z18ET? That is for the fuel injection system.
DylanM
Car: Datsun 720 king cab 2wd
Try this, it's the z18 wiring diagram I'd try it myself but i have no use for it. here's the link - Off topic this is my first post here.. ever, i just got a king cab and will post pics next week. Hope this link helps yahttp://datnet.org/Technical-f3....html
flinterman2000
Thanks man. Its just what I'm looking for.
Return to “Datsun 720”
