Throttle Body odity
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Does anybody have this little notch, in their throttlebody?
I was cleaning the intake on the 1994 Q45t, this evening, and noticed this notch. It is perfectly smoothe, but I know my other 1994 Q45 does not have it. I wonder if it is a late model thing, or a touring model thing. It looks like the TB has been replaced, and the plenum has been removed at some time.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Honestly I cant remember what mine looks like, but are you referring to the little groove next to that thing that sticks up???
It looks perfectly normal to me... I dont know why they woudl replace the TB???
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Yes, there is an area of the TB, that is plastic, and there is a deep groove in it. It looks like a half moon, in the picture. It is not visible, when the butterfly is closed.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
As I look at it further, it looks like a place, where the plastic par has broken off, from binding on something, while whoever had it off, was tightening it. Like it chipped off, while someone was prying it apart (which I know no one would be stupid enough to try that on the inside of the TB).
The car ran much better, today, after the TB & MAF cleaning. As long as Idon't go WOT, the car drives superb. It beggs to be opened up (or is that me begging to open her up?).
I think it is from a big-fisted mechanic, in a hurry to re-assemble the car. I hope it isn't what is causing the car to bog at WOT.
SFBayQ45
Car: cars
Quote »The car ran much better, today, after the TB & MAF cleaning. [/quote]
If cleaning the TB & MAF will net better performance, I'm all game.
Jeff - do you have any special instructions on how to do this for a non-mechanically inclined fella like me?
Wes - do you have a write-up about this that you can share?
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
I saw a nice little write-up on http://www.q45.org
Basically, use a full can of electrical (brake) cleaner, on the MAF, and a full can of Throttlebody (Fuel Injector NOT Carb) cleaner on the TB and inside the plenum. Hold the butterfly open with a screwdriver - it is much easier that way.
Eventually, the fluid running out of the TB is clear.
It is REAL HARD to start the car, once you clean the TB. You might want to let it dry for a while, before starting it.
Rex
Car: None
Just for those who don't go to the link, remove the MAF to clean and the TB (throttle body) can be cleaned while on the car if you remove it from the car/engine you'll need a gasket.
EDIT: Based on the additional info below.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
I do remove the MAF and upper filter housing in one piece, and take the plastic piping off the TB, but do not remove the TB from the plenum.
DAEDALUS
Car: 1990 Infiniti Q45
You can remove the TB, just have a new gasket on hand. Then you can clean part of the plenum or, if you're Greg, all of the plenum.
That little notch, if I'm not mistaken, is the air passage for closed-throttle (idle) operation.
It leads to a tiny orifice on the outside of the TB with a hose connection, and it gets all funky in cars that are "granny-driven".
elwesso
2007 BMW M Coupe
yes I do believe that is from the TCS...
There should only be a slight gap or any passage, as the IAC will take care of the rest.....
You can clean the TB with the TB still on (but will do a marginal job), and you can clean the plenum without taking it off... But eventually its going to need to be taken off to be THOROUGHLY cleaned....
SFBayQ45
Car: cars
Based on previous threads, it seems like a fuel rail flush is strongly recommended. I've just dropped off my car at the dealership to have that done. The counter rep explained that this also involves some sort of chemical flushing down the TB that also cleans the fuel rail. According to the rep, there isn't any specific job just for a "fuel rail flush" alone, therefore this work they're referring to would total $200. Am I being taken?
If this work I am agreeing to involves cleaning the TB, is it safe to assume that I don't need to clean the TB just as Jeff is doing above?
Odd. Based on previous posts people are able to purchase just a fuel rail flush.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
SFBayQ45 wrote:The counter rep explained that this also involves some sort of chemical flushing down the TB that also cleans the fuel rail. According to the rep, there isn't any specific job just for a "fuel rail flush" alone, therefore this work they're referring to would total $200. Am I being taken?
The intake passage is for air, and eventually the fuel sprayed into it from an injector. I think what they are offering you is a chemical fogging cleaning of the intake passage. While good as an item for general maintenance, it is no substitute for elbow grease when the intake and/or throttle body is truly dirty.
The BG fuel rail flush is the only good on vehicle one of which I am aware. I bet your dealer doesn't offer it.
Look at the http://www.bgprod.com site and find a shop that does. Don't believe the icons, call the shop first to confirm.
elwesso
2007 BMW M Coupe
After seeing what builds up inside there, one of those intake foggers I see worthless UNLESS its clean and you do it say every 90 days to keep clean.....
Just like BG44k isnt meant to clean dirty injectors... to keep clean ones clean.....
Recleaned the MAF yesterday and did the TB a couple hours ago. Idling is significantly smoother, and what I saw inside wasnt pretty:
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Jes!!!
Put some towels under the TB, to catch the nasty stuff, so it doesn't get on the rocker covers!
Did you see the half-moon shaped piece cut out of the dark plastic ring, inside your plenum?
DAEDALUS
SFBayQ45 wrote:Based on previous threads, it seems like a fuel rail flush is strongly recommended. I've just dropped off my car at the dealership to have that done. The counter rep explained that this also involves some sort of chemical flushing down the TB that also cleans the fuel rail. According to the rep, there isn't any specific job just for a "fuel rail flush" alone, therefore this work they're referring to would total $200. Am I being taken?
HORSECRAP. It's one thing to not offer a service. It's despicable to lie about what the available service actually does. Ask the rep how the cleaner gets into the fuel rail from the TB!
elwesso
2007 BMW M Coupe
If you get the car to backfire through the intake and open the injectors at the same time, that should REALLY blow some crap out (and more in) :D
Jeff Williams wrote:Jes!!!
Rocker covers? What? You lost me. I'll grab a towel next time though. :)
I didnt check for the plastic ring thing. It was almost 6pm on a dreary and I really couldnt see it if I tried. The lighting in those photos is thanks to the camera flash.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Rocker covers, Tappet covers, Valve covers, whatever.
I know hte feeling, with the flash. It is really ahrd to use the camera as a flashlight. It tends to give you a headache.
Isn't working in the dark cool?:D
Honestly, I dont know where or what the rocker/valve/tappet covers are. I just know that when they leak I'm supposed to pay someone to replace them. Don't give me too much credit when it comes to the technical aspects of automobiles. :)
Tomorrow I'm going to remove the air duct and take more pictures. I'm also curious about this moon-shaped thing youre referring to.
-Jesda
elwesso
2007 BMW M Coupe
The valve covers are those gold looking things that are bolted onto the sides of the enigne at an angle. They have the black plastic piece of death, where the plugs are located under.....
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Are you talking about the little chip on the black plastic? Hmm, don't remember that.
elwesso wrote:If you get the car to backfire through the intake and open the injectors at the same time, that should REALLY blow some crap out (and more in) :D
LOL at Wes! :D
I'm anal and don't clean the TB on the car, the emulsified gradoo can run down the plenum & make a mess.
Either way it's a PITA to get it good & clean, but if it's off the car you can be certain you don't miss any spots.
Related comment, kinda.....if any of you guys plan on getting an Eaton charger, for Chrissakes never, ever, ever spray that stuff in the throttle body on the car. The rotor set is coated with teflon and that stuff comes off as fast as a prom dress if carb cleaner runs through it.
elwesso
2007 BMW M Coupe
I agree... I cleaned my TB in just the same way mentioned here, and it was STILL CAKED with CRAP after the cleaning...
In order to get sparking, you MUST remove and scrub (or use my paint/varnish remover method!)... Perfection is a PITA to achieve!!!
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
I use a toothbrush and carb cleaner after holding the butterfly open with a bungee cord on the linkage...and I use a light. :)
BTW: if it's really Teflon applied properly, carb cleaner can't touch it. Go to DuPonts web site and read the resistance charts. Flourine is spooky stuff when you add it to polyethylene or polypropylene.
redmanfx
Car: 92 Q45a
elwesso wrote:In order to get sparking, you MUST remove and scrub (or use my paint/varnish remover method!)... Perfection is a PITA to achieve!!!
I absolutely agree with you Wes. After cleaning mine, I am convinced the best way to clean it is to take it off and do it right. The caked black mass of hard crisby pan baked crustatious barnicled crap just doesn't come clean with the tooth brush and cleaner while still attached to the plenum. You clean get it a little clean but to really spit shine the inside and get all your performance back, take it off and clean. You get better angles and can really get it from the other side without all that cleaner dripping down your cars throat. The difference is incredible IMHO.
It's a pain,but worth it.
red.
elwesso
2007 BMW M Coupe
I can only imagine how yours was redman!! :eek: :vomit:
Only problem is, you will see how dirty the plenum is and then youll want to remove that and get it clean... Then youll see how dirty the intake runners are, and want to clean those as well.....
Its a never ending process to perfection!!!
redmanfx
Car: 92 Q45a
elwesso wrote:I can only imagine how yours was redman!! :eek: :vomit:
SSSHHHHH! You'll scare people off..... You are sooooo right.
red.
squeefoo
1999 Infiniti I30
Toothbrush works great ....If it's not been allowed to become a crusty, barnacled mess from deferred maintenance. Should be part of a normal routine like fuel filters and oil changes. Any car with a TB should have it cleaned regularly. How did it get that way?
