Throttle body leak??
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
So I got a chance to go work on my pile some more and did some pressure testing. Found my BOV was leaking at the flange. Fixed that, then I found the next leak at my throttle body. Sent away for a new gasket got to love cometic gaskets! $3 for that sucker vs $15 for the OEM one. well I pulled the TB off put some RTV around it and see what happened. Still leaking but not as bad as before but I did spy a leak coming from the shaft. Anyone else test there system and find a leak at the shaft?
FerrariTruck
Yellow4g63 wrote:So I got a chance to go work on my pile some more and did some pressure testing. Found my BOV was leaking at the flange. Fixed that, then I found the next leak at my throttle body. Sent away for a new gasket got to love cometic gaskets! $3 for that sucker vs $15 for the OEM one. well I pulled the TB off put some RTV around it and see what happened. Still leaking but not as bad as before but I did spy a leak coming from the shaft. Anyone else test there system and find a leak at the shaft?
my TB is leaking there too. Its minimal but i can hear a change in idle when play with the shaft
240z4u
Car: '95 Nissan 240SX
Pretty common IMO, seems to pop up regularly. I got lucky and mine does not leak. There is no fix for it.
Either get a different T/B or tune around it best as you can!
s14_sport
I have the same exact problem. I have tried 3 different Q45 TBs and they all the leak from the same place on the shaft.
jdmser
Car: duh
pretty much the same as 240z4u said
zerothread?id=351659
Yellow4g63
You know what blows! I had a extra intake manifold with the throttle body and I tossed it the trash while I was cleaning up over the summer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! arggggg.
wrgibson
Car: RB Hatch
Add another one to the list of people.....I've got the same problem.
