nismo521 »
https://forums.nicoclub.com/nismo521-u11975.html
Thu Aug 25, 2005 8:54 pm
Had to pull the intake off of my car this week. As I was doing so, I noticed this monstrosity tee'd off the pipe right before the throttle body.
So, I disconnected it from the intake pipe and unscrewed it from the fan shroud. Then ran to the parts store and picked up one of these bad boys.
Sorry it's not in the package, I already had it in the pipe before I took the pic. Basically, it's a freeze plug. A plug of rubber with a bolt going through it and a washer on either end. When you tighten the bolt, the rubber expands laterally and fills up the area that it's in (don't tighten it too much, you'll crack the pipe ). When done, it will look like this.
As far as the difference in the sound, I don't know yet. Once I get done changing these 1801928341 four inch long heater hoses and get the car back together, I'll post my impressions and try to get a vid clip of the sound.
