throttle body coolant line to turbo
disturbed.)
Car: 94 240sx vert sr20det 5 speed gt2871r dead for now,
04 Frontier XE vg33e 5 speed HG46
ive been searching for close to 3 hours and cant find a flow diagram or any info on how to bypass the throttle body coolant line as a feed for my gt2871r. i have the return line on the turbo already hooked up but need an input and im bypassing the deicing line so i figured i might as well solve two problems at once. which line coming from the engine is the pressurized line to the throttle body? and which do i cap off? it doesnt look like it has to be looped or am i missing something? this is on a redtop or id just loop the tb line and run the turbo coolant line from the water neck. thanx in advance
disturbed.)
or if any1 has a suggestion for how else to do it without spending any money i.e. looping deicer and another pressure water source that would be helpfull too.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
What's wrong with the stock feed off the back of the block? You wouldn't end up with a coolant line running across the front of the engine either.
disturbed.)
as far as i can tell there isnt 1 previous owner didnt have a water cooled turbo so there is no nipple on the heater hoses
disturbed.)
transmissions out on my truck and my old motor is at a different storage area than the garage im building this project in but ive got to get this done today so ill have to walk from shop to shop to examine the other engine and which hose its on then go back the garage and run the line to tb port on that line
Hijacker
Car: '92 240sx Convertible
'94 F-150
You could always find someone parting out an SR for that hose coupler. Also, I'm sure with the proper P/N from our FAQ, you could order it brand new through Courtesy Nissan or West Covina Nissan.
disturbed.)
thanx i got a look at my old motor and hooked em up yesterday. ive spent entirely to much money so far and needed a free solution. the line from the engine pointing towards the front of the engine gets capped. the other that points down and is very tough to get to can be rerouted from the throttle body and bends nearly perfectly to meet with the braided return line
