EdBwoy wrote: ↑Thu Jul 20, 2017 4:45 pm...
For the throttle body, no special tricks except remember to not open the valve all the way. In fact, interfere with it as little as possible.
Remove the throttle body. Get throttle body cleaner or carb & choke cleaner and spray both sides of the plate. The body itself will be easy to clean, but you want to wipe the plate without necessarily opening it. Put a finger to prevent it from opening as you wipe it, or just spray and let the chemicals do their magic. I use paper towels and usually I soak one well enough and slide it past the plate, which opens the plate just so slightly so I can clean the contact surface of the plate and the body.
I still have never damaged a TB by cleaning it.
You might need a gasket handy, just in case you damage yours on the way out. And hopefully yours is not too gunked up that you need an idle air relearn after cleaning it.
EdBwoy wrote: ↑Tue Jun 12, 2018 10:07 amI agree.
One caution for the MAF sensor is to do it dead cold. I'm talking about letting the car sit overnight, not even driving it around to reposition it in your garage.
Although I don't encourage anyone to do this, I have cleaned a fair number of Nissan throttle bodies and never ruined them. Battery connected/disconnected, TB mounted/unmounted, ... as long as you don't excessively open the butterfly and play with it. The only reason you need to open the butterfly is to access a thin strip of gunk where the plate meets the TB bore. Typically I wet a napkin with the cleaner and slide it under the plate and it does the job well, or you could use a Q-tip (cotton bud, my non-Americans) to clean as far as you can in a throttle plate closing direction then go to the other side and use the Q-tip gently as well.
However, proper procedure after removing the TB is to replace the gasket. Then there's a slim chance you'd have to do the Idle Air Relearn procedure.
Non-stick cooking pans and Teflon (PTFE)
Here's something I don't see spoken about often. Most throttle plates I have dealt with will have a coating around the hinge, most probably Teflon to help keep the plate motion smooth. Most times, these cleaners will make that coating disappear.
Is that catastrophic? Most probably not right away, but the lack of Teflon makes it that much easier to gunk up and the throttle to stick... ya know, like a non-stick cooking pan with the PTFE scraped off.
My opinion is that this is not necessary, and as EniGmA points out, it skews unfavorably on the potential harm-benefit spectrum based on many user-testimonies.
The first thing I'd go for is to try doing the Idle Air Volume Relearn. You can find the procedure in the EC section of your FSM (factory service manual).
