Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Oct 06, 2003 9:14 am
IAC (or AAC as it's called in the service manual) is a valve that's controled by the ECU and puts more air into the intake on the engine side of the throttle body. The ECU uses this to maintain idle when you turn the A/C on, use the power steering, etc.
I'm not sure of the exact location, but it'll be mounted to the plenum or intake manifold, and should have a two-pin electrical connector and a set screw. In many cases, people will set the base idle up to compensate for a dirty throttle body - after it's cleaned, the idle will be higer than spec. until the AAC valve is set back to normal.
Heath
