Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Mon Oct 27, 2008 3:42 am
I just discovered after observing my mechanic how to open up the throttle body flaps so that you can clean the inside for G-35 6 MT as you replace the after market air filters.
1. Put the car keys in the ignition, and leave it at the "ON" level without starting the car.
2. Put your parking brakes on.
3. Put the car in gear--any gear.
4. Step on the throttle or accelerator, and the flaps will automatically open by themselves and you will be able to see the darkness inside the chamber.
5. When you are done cleaning, do the same steps or just step on the accelerator pedals so that the flaps can go back to their original closed position.
6. Then you will have to conduct an engine relearn sequence, which I have little knowledge about. StevetheTech will chime in and give you the full details of that sequence and how it is also done. if you can't do the sequence yourself, take it to an infiniti dealer so that they can do it for you.
