http://scialert.net/qredirect....d=pdfh ... al-ihm.pdf
Rotor composition and cracking:http://www.mitsubishi-motors.c...6.pdf
"Obviously, these numbers were going to piss on StopTech's parade and ours. Even though the big brakes were far superior in terms of rotor temperatures, pedal feel and modulation, the longer-than-stock stopping distances would undoubtedly raise some questions as to the validity of spending several thousand dollars on an upgrade."
"In the real world, brake engineering and balance isn't just about how fast you can stop. Brake engineers and OEMs know this, and it's the last piece of the puzzle we didn't get to test between the three set-ups. Often ignored in the aftermarket, braking stability in a turning/braking situation plays a critical role.
The Society of Automotive Engineers (SAE) has a set procedure and protocol for this. Essentially, the test measures how a car behaves and where it ends up when the brakes are fully applied when circling a skidpad at its limits. A car with more rear bias will rotate and end up well inside the original line of travel, while a car with too much front bias will push well outside the skidpad. Maintaining a balance that allows the driver to keep going where the front wheels are pointing is critical and is also one of the factors behind StopTech using less-than-optimal rear bias in order to keep the car on line.
http://www.modified.com/roadte....html
http://www.wsdot.wa.gov/resear...1.pdf
http://www.mscsoftware.com/sup...5.pdf
http://books.google.com/books?...num=8
