AZhitman wrote:1.) David - Plugs should be changed regardless. Go NGK platinum ONLY, get them from Joe at Scottsdale for a good deal.
2.) Valvetrain noise can be remedied by changing oil viscosities - Several "purists" here swear by Mobil 1 20w50, as well as Valvoline Synpower.
3.) Fuel filter is an easy DIY. Remove fuel filler cap, pinch off inlet hose (or have some rags ready) and loosen the "sleeve", then upper and lower fittings.
1.) Run VIN at dealer or Infiniti customer service to see dealer performed maintenance.
2.) AZHitman means 15-50W M1, found at Sam's Club and other fine automotive retailers (for more money). Not recommended for N of Mason Dixon or W of Sierras or Cascades in Winter.
3.) Read the posts on this. You will want to pull the pump fuse, turn engine over, then loosen gas cap before accessing the filter.
