That tube is the air relief valve. You're talking about the item in the center of this picture, correct?
It's used during drain & fills of the radiator to help burp air.
I wish I had bought one a few years ago. I borrowed one years ago but the head wasn't small enough to fit into the spark plug hole I could peek straight down but not all around in the bore. Didn't see a screw or any damage so I went to plan B and C. Years later after the noise was still there I took out motor and pulled heads to find the screw in it. It was way down on piston 1/4 " from edge of piston out of view of the borescope I had borrowed. This car has been parked for four years cause I feel a stupid screw.barnaclebob wrote:If you are looking for a good reason to buy a borescope, this is it... My wife got me one a couple months ago and it worked great to make sure my screws were still there at 144k miles. I'm going to go with the if it ain't broke don't fix it theory on this one. You just need to remove the rubber duct from the throttle body and hold it open to inspect the screws.
my2001qx4 wrote:I wish I had bought one a few years ago. I borrowed one years ago but the head wasn't small enough to fit into the spark plug hole I could peek straight down but not all around in the bore. Didn't see a screw or any damage so I went to plan B and C. Years later after the noise was still there I took out motor and pulled heads to find the screw in it. It was way down on piston 1/4 " from edge of piston out of view of the borescope I had borrowed. This car has been parked for four years cause of a stupid screw.barnaclebob wrote:If you are looking for a good reason to buy a borescope, this is it... My wife got me one a couple months ago and it worked great to make sure my screws were still there at 144k miles. I'm going to go with the if it ain't broke don't fix it theory on this one. You just need to remove the rubber duct from the throttle body and hold it open to inspect the screws.
