Thoughts?
radigan
Car: 2013 M37xS
Hey guys,
been a while since I posted anything here. Wanted to see what you guys think about this mod I'm debating on doing. I think the 370z rims would look sick on the M. I tried to fit the rear on to see how it would look. It looks awesome I think, only issue is its sticking out a bit imo. I am currently on coils and plan to lower a bit more, not sure how much that will help as the wheels go up and in when pressure is applied? Will it rub? what can I do to have it look more flushed?
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
1) smaller tire perhaps...what size tire is that?
and/or
2) get your fenders pulled a little
06M4.5
Car: 2006 M45
camber and a pull will help.
Try to see if you can shave off a few mm from the back of the wheels.
What are the specs
wheel size, tire size & offset
mexillis
Car: M45s
I agree with trying to add some camber. Id also say go a little lower, what height are you at now? Looks like your sitting at 27" or so from the ground so you could go down an inch if you wanted to.
mexillis
Car: M45s
Here's a pic of my rear wheel when raised compared to ride height. It amost looks like it sticks out the same as yours. You can drive around and not worry about rubbing but if you want to be more flush your gona need to lower it some. Mine tuck in pretty good when dropped an inch. Image
Hard to be accurate since dfferent angles when taking the picture affect the look of how much it pokes.
06M4.5
Car: 2006 M45
Take a look at this:
http://liberty-vip.com/?p=6036
