burntricer »
https://forums.nicoclub.com/burntricer-u53313.html
Sun May 18, 2008 12:05 pm
hey guys.
My redtop seems to be running good now, and i like the abundance of power that i have. Im running a stock Redtop, with a T25, holding about 10psi, basic supporting mods,
-Adj. FPR-Greddy FMIC-3" Turbo Back Exhaust-Topspeed bottom mount mani-300zx TT fuel pump-Stock SR Ignitor
althought im happy with the current setup, I would like to hit about 350 WHP eventually.(i have a spare block so that will get the monster treatment, the block has a Cometic MLS h/g and ARP studs, plus its all been rebuilt with HKS springs/retainers)im leaning toward the following.
BC stage 1 camsSAFCROM tune/maybe JWT
My questions are as follows.
I am currently running the KA24E Maf. I understand I will out flow it. I have read that the z32 MAFS is good, but ive also read that the Q45 is good aswell.
What one is the best for running 350+ hp?, also easiest to wire?
Turbo wise, im kind of a a loss, i understand compressor efficency maps, however i cant seem to get my hands on the ones for the
a) 2871rb) 28RSc) S15
What about wastegates? when running that much hp i would much rather run something like a Tial 55mm Wastefence, Are the above turbos available without an internal gate?
Injectors? i understand i will have to upgrade, but to what? 750s? 550s?
Now i want to remain on pump gas, this is my summer driver, and i want it to be reliable, aswell as maintain about 800 kilometeres to a tank (what i hit now)
I will be running the same manual boost controller as i am now. i have had enough problems with boost leaks, so i dont want to run massive amounts of boost, 10 is good enough for me. and with the above mods im sure that 10psi on a bigger turbo will yeild easy results.
thoughts?
