True. The SE-R/Spec V is exactly what it's supposed to be from Nissan's idea behind it, and econobox with balls. It's more designed to be in the realm of the Civic Si and RSX Type S than the SRT-4, WRX, etc. If you ran it against either of the first two cars listed, it would probably win. It weighs about as much as either, but has a good bit more torque. If you took it up to top speed the RSX would win because it has more top end, but top end is not something you use day-to-day.
It's funny as crap to just listen at work, The pool I work at is separated from a busy street by just a small hill. You can hear people going in and out of the neighborhood and the neighborhood across the street. Every day, at least 5 times, someone squeals tires and floors it. The big redneck trucks shake the ground with their V8s, while the Civics and Integras buzz off. The guys with the Civics and Integras (note, mostly those two cars, but not always) take the car all the way to redline before shifting.
How can they not hear the power die off? I know (for instance) my car falls flat on it's face at 6k rpm, compared to 4500rpm, that is. Meaning that the car will pull nicely to 6750 (redline) if asked, but then the kick in the pants felt at 3000 just isn't there anymore.
My point is that the SE-R is the torquiest car in it's group, so if the goal is an econobox with balls, it's the best choice. If you want something higher performance, higher dollar, and less economy, then go with the SRT-4, WRX, etc. I just assumed it was all about the performance aspects, rather than the bang-for-buck-relative-to-class/market factor. The upper-power and dollar cars also get worse gas mileage, if I'm not mistaken. Turbos make engines gas happy when used properly
*edited for formatting cause huge blocks of text are hard to read*
