VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Apr 11, 2023 4:08 am
When bolted in place the wheel and spacer can be considered as a unit, so if the spacers are correcting an offset for different rims, there's no change in track and no problem. If they're being used to widen the track then the net effect is to move the rolling center of the assembly outboard, which puts off-center leverage on the bearing and can (not necessarily will) accelerate bearing wear or cause alignment/suspension issues.
